cleb
- 0
- 0
- Huntsville, AL
I looked under the Deuce this morning to see gear oil on the inside of the rim :/. I need to replace the inner and outer seal on that axle (Rear) before the 4th. Is there a Napa number for the seals? I didn't find anything in the cross reference section, just the pinion seals. I would order from OD Iron or such, but it probably wouldn't make it in time.
EDIT: I heard that RTV can be used in place of the cork sliver for the keyway? Is this true, and will it hold up as well?
TIA,
Caleb
TIA,
Caleb
