Rear window crank and TAILGATE WINDOW REGULATOR
Indyharleyguy
61
Carmel IN
Hi All, on my 1009 the rear window will not crank the last 1 inch or so. Awhile ago I purchase in the box a brand new interior mechanism from a guy. He said it would work. The problem is the part on the interior mechanism that connects to the exterior crank is different. I purchased a new crank and same problem.
On the right is the interior mechanism and the left is the new crank. Any idea why they don't match and where to buy another hand crank to connect to the interion mechanism?
This link shows what I have.
Indyharleyguy
61
Carmel IN
This link appears to show the outside handle crank I need? It looks like I need another piece to attach to the outside crank?
WWRD99
1,664
York Pa
If you go on LMC they have the parts you need...the end is called the clutch...thinking you'll need all the parts for it since there's a spring and block and other stuff to make it work. If you look up this part number on their site you should be able to find the rest of the stuff you need.
36-0782CLUTCH-MANUAL WINDOW LOCK
