Rear Wiring Harness for M931A2
Karl kostman
880
Fargo ND
Get your ohm meter out and start hunting down where the current stops, I would also make sure the bulbs are know and while the bulbs are out ohm out the sockets. If you have the wiring diagram another very goot spot to start is to locate and cleanup all the grounds, its kind of a pain but it sure works to reduce the work in the end!
good luck
Karl
