rebuild a 6.2 or a 6.5 injection pump
84cucv1ton
New Jersey
i have both. going to a turbo. going to get rebuilt pump and injectors at the same time.. not sure if the 6.5 pump is worth the extra 200. heard a lot from a bunch of different people. not sure . what do you guys think?? thanks
67_C-30
Sweet Home Alabama!
The 6.5 pump is going to have more potential for power if you decide later you want to lower compression ratio or whatever and go for more power. The 6.2 pump will be adequate if you turn it up 1/4 - 3/8 of a turn when you put the turbo on, but its not far from maxed out there. It just depends on what you think you'll do later on.
ken
25
Houston Texas
You'll have to be more specific. Are you talking the DB-2 pump vesres the DS-4 pump? The DS-4 is eletronic. And a major piece of crap!! The DB-2 will flow plenty of fuel. Even with the marine injectors.
84cucv1ton
New Jersey
thanks its all stock other then a kit to stiffen the main caps. stock pump it is. save the other one for the rebuilt balanced 6.2 i will do this winter. not sure if its a db4. ones i got a from a friend. were used in early 90s buses.
67_C-30
Sweet Home Alabama!
The DB4 is electronic, and looks totally different than your 6.2 pump. The early 6.5 is a DB-2 pump just like the 6.2 pump does.
