Sergeant1983
- 1
- 18
- Memphis TN
That is very nice. But you are showing a rear drive shaft in the first post. I just had one rear propeller shaft made for an M1009 all parts new. It was about $200.PS Found this online, but nothing in the blogs about the actual length it should be.
http://www.oreillyauto.com/site/c/s...986&vi=1050679&make=Chevrolet&model=K5+Blazer
Well with a slip joint that sure will vary. I will measure weld to weld on the rear prop shaft and then we can go from there. But I can measure the rear U joint center to front U joint center if you want. I will post pretty pictures of my new propeller shaft. Give me till this evening. I am not at home at the moment. Duty calls. Have a great day and stay dry.Drive shafts are usually measured center to center on the joint ends.
