Recommended dose of Diesel Kleen to fuel tank for 6.2
biped
Fort Davis, Texas
1 oz per 3 gallons diesel? I can't remember and I haven't been driving the truck lately. Diesel Kleen says 80 oz services 250 gallons diesel. Mild climate. I think that's what it works out to be. Any reason why it would be more or less?
Biped
CUCVLOVER
Just dump some in and call it good. I never bothered to measure it out in any diesel. 6.2 Detroit, 6.6 Duramax, 7.3 powerstroke, tractors and equipment I just dump some in and run it
Sent from my XT1585 using Tapatalk
Floridianson
2,502
Interlachen Fl.
I switched to Optilube and started with double dose then per instructions per gallons added. Stuff is not cheap is the only reason for me.
MarcusOReallyus
816
Virginia
Eh, Drock? Did you miss the thread a while back about that? Lubricity tests showed MMM reduces the lubricity of your fuel. It's not a good thing for these beasts!
Still use it in my gassers, though.
1,178
Still have a small stash of whale oil here.
That's all I use and it's 100% natural so it's good for the environment.
Drock
12
Eatonton GA
No I didn't see that. I only just recently started using MM in place of 2cycle oil. I've bin nursing a leaky injection pump throttle shaft. The 2cycle oil would slow the leak, MM stopped it:shrugs: Perhaps I will use a mix of the two?
