FireFighterHill
Banned
- 1,540
- 62
- 0
- Riyadh, Saudi Arabia
I just talked to Thermo King of Orlando about pricing on a roof top a/c solution for a Deuce. A few things I found out.
A complete roof top A/C and heat solution that runs off of 24volt can be had for under 2000 dollars that includes the compressor, compressor mount, lines, and all fittings.
He gave me a break down like this
1450 for the R-9777.
330 for the compressor and mounting bracket.
150 for the lines and fittings.
BTUs Heating -- 45,000 BTU/hr @ 100º F
(11,340 kcal/h @ 37.8º C ) air temp. rise.
Cooling -- 25,000 BTU/hr with 36º F (6,300 kcal/h with 2.2º C) refrigerant temp. and 80º F (26.7º C) wet bulb entering air
Air Flow 400 CFM (680 m3/h)
Weight 65 lbs.
Motors Evaporator -- one, 24 VDC, three-speed
Condenser -- two, 24 VDC low profile
Current Draw R9777-0-24 Heater A/C (24 volt)
R-9777-1-24 A/C Only (24 volt)
Models R9777-0-24 Heater A/C (24 volt)
Weight 65 lbs.
