Red paint on front of engine.
joeelutz
North Carolina
I recently purchased a low mileage 2000 M1045A2 with the 6.5 and 4L80E. The front of the engine pulleys etc are painted red. Rather sloppily done. Anyone know why this is or if it means anything? I've seen a few others with the red pulleys.
TOBASH
3,364
Brooklyn, NY
Everyone knows red paint lets you go faster. Discovered by Enzo Ferrari.
My grandad would also joke that red socks keep your feet warmer in Winter. So maybe winter advantages?
I’ve never seen any documentation about red engines before.
Best,
T
Milcommoguy
2,167
Rosamond, CA
I am guessing ??? it is someones idea to spray "red rust-oleum" on the cast / bare steel parts after a rebuild. It say's front end is done sign off. Quick and dirty, MTCW
Who cares at 37 MPH with the hood down, CAMO
DREDnot
435
Phoenix, AZ
Ive seen that, too.
I also wondered what it was about and it seemed to be mostly on serpentine belted engines missing the belt. My guess is it was done to warn that the belt was missing, or to not start the engine or something like that???
CMPPhil
376
Temple, NH
Hi
If the fan blade tips were painted red, I would have suspected safety warning turning part. Fan blade tips on all my engines are painted for that reason.
The painted to protect from corrosion during long term storage, makes way to much sense to be the reason.
Cheers Phil
sandcobra164
288
Leesburg, GA
Desomodromic has the correct answer. Do a search for mil standard 3003 (B) to learn preservation methods used when storing rolling stock long term. The paint will wear off after a short period of use. We preserved a lot of HMMWV's where I work at because the decision to rebuild versus adopt the new J.L.T.V. was still up in the air.
