Reduction Unit Parts Needed
ltdaniel
14
Three Rivers, Ca
I need help finding this.
During the disassembly of the 2 Speed Gearbox on the back of the trans I found a broken snap ring a big one almost 13" across.
Spring release, reduction unit clutch 12 1/2 diam. part number 7411670
Also the drain plug filter screen got mangled all I need is the screen.
Complete unit part number is G749-8328544 which consists of:
Drain Plug YT-8614227
Screen YT-8614244
Dan McCluskey
292FARMER
New Hampshire
Screen YT-8614244
Dan McCluskey
where have you tried? ive had good luck with marty down at memphis equipment...idk if fatsco transmission will have parts for the reduction side.
NDT
7,529
Camp Wood/LC, TX
If you dig around on this site, it has been said that the wavy spring can be omitted. I can’t verify that. Probably can omit the screen too if you keep your oil clean.
rustystud
3,394
Woodinville, Washington
Fatsco does not carry any parts for the reduction side of the HydraMatic transmission. Tried that years ago. According to the sells rep, those parts are so obsolete that no one in the world will ever make them again. Guess he was correct. I've searched and finally had to buy spare transmissions to cannabilize for parts.
