refurb new deuce
bob b
pottsville pa.
i just got a m35a2 deuce with c turbo no winch i crawled all over truk and can't find any problems with it so far . But what can be hidden and will pop up later i don't know and hope they don't. i want to paint it vietnam era o.d.what would that be as far as color shade also what is the best way to clean under carraige and frame for painting need some dents pulled out of hood and straighten out driver side rear of box . Belts look new want to change oil and check all fluids what do you recomend for oil in engine multi visc. or straight sae 30 wgt. which i presume would be detergent ,does any one ever use lucas oil treatment when they change oil in there deuce and do you or don't you recomend it. what do i haved to be aware of as a trouble item on trk injecter pump ,turbo',air comp,would like to drive places with it what should i be concerned about so i avoid breadowns and major problems . thanks bob bplease email me with any suggestions and or post it
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Check the brakes and the wheel bearings, those should be first on your list. Brakes are self-explainatory and I had a wheel bearing go out on me while on a road trip. Very expensive while on the road and the down time sucked too! Lots of guys use rotella 15w40. Bring spare belts and fuel filters with you. That covers the big stuff. Feel free to ask any questions you may have.
2Deuces wild
calif
Stick with the regular stuff it works fine. It's a lot less expensive over all and it a old truck. I use 15-40 Rhetta. Axle leaks are common, Have a seal kit handy. Check the tork rod bushing for wear. I have a 68 and these are the problems I've had so far. Some trucks have been converted from 5 dot brake fluid to 3 dot. Figure out what kind you have. If its purple it's 5 but if its old it may have turned yellow. I used a turkey baster and a glass jar. I pulled some fluid for the master Cylinder It was yellow, I then added 5 dot and they mixed. If it was 3 dot they would have not mixed.
