Registering a deuce in NH and I don’t have a title
silverbullet72tnt
Northern NH
N.H requires title for three axle rigs. My deuce has no title as it was a yard truck for a long time. I’ve been told I can do a bonded title. But I’ve also read I can register it in VT and then transfer the reg and since VT doesn’t require a title NH will then issue one.
Any ideas or suggestions or other input?
Kaiser67M715
26
NH
Depending on use, you could apply for antique truck title, but that is also dependent on year. Beyond that I won't comment anymore.
Sent from my SM-S920L using Tapatalk
silverbullet72tnt
Northern NH
Title for a Deuce in NH
Hello!
I tried the regional section, but I didnt get much so I'll try here.....
I just bought a deuce (53 gasser) and it didnt come with a title. In NH anything with three axles regardless of year needs a title. It appears I can either get a bonded title, or Ive been told that VT will register out of state rigs for out of staters and it wouldnt need a title, then after a period of time I could transfer the registration to NH and get a title....
I guess I am looking for either advice on which way is fastest/easiest, or anyone experiences with the above or other ways to do this.
I will try calling state DMV today and see if I get anywhere with them
Sgt C
388
Hudson/new Hampshire
New to forum and just saw this. I know the response may be a mute point by now but you dont need a title for 3 axles if the weight is under 18,000lbs. I registered my deuce about a month ago without a title. Only needed a NH recognized bill of sale. Put antique plates on it. No difficulty encountered.
Kaiser67M715
26
NH
Be careful here, as it is the gross vehicle weight that must be under 18,000lbs, the curb weight (unloaded, no passengers) is only about 13,000lbs, that means if you register it under 18,000, technically you can never haul the full GVWR (gross vehicle weight Rating) which is roughly 23,000lbs. The law is worded in such a way, it states a title is required for a truck with three axles OR over 18,000lb GVW...
When I tried to first register my truck, we called the state DMV, and they said, if it had 3 axles, it needed a title, regardless of GVW.
Now I do know a few guys that are running around in a deuce with no titles, regular plates no issues, I even know a few guys with 5 tons that don't have CDLs, even though it's required for a truck with a GVW of over 26,000lbs, but notice right there it's the GVW, not GVWR.....
Sgt C
388
That is great information! Since my truck had already been registered in NH, the state basically copied what was on the old registration. While I dont plan on loading it even remotely close to capacity, I'll have to research this further and see if I can apply for a title.
