Relative compression test
martinv
58
Glyndon MN
Today I decided to try a 'relative compression test' on the M35A2. This method uses a current probe on the battery line and measures current peaks caused by the compression of each cylinder. There should be 1 peak for each cylinder, then the pattern will repeat as long as you are cranking the engine.
Initially there is a very large (and expected) current spike. Shortly after the waveform stabilizes and this is the area to analyze.
Note: Fuel turned off so the engine wouldn't start during the test.
Here is my full waveform including just over 2 seconds of cranking:
And here is a zoomed in view showing each cylinder number 1-6:
Which cylinder is actually #1 cannot be determined without some other method of triggering, but the goal is to look for a pattern. If every 4th and 5th peak was very low, this would indicate 2 sequential (in the firing order) cylinders have low compression.
I don't have much experience analyzing this method but it appears my engine is fairly consistent. This means all are good, bad or OK. A real compression test on 1 cylinder would tell which is the case. This seems like another good thing have as a baseline, so when you have a problem you can compare to a known previous state. I already had the test equipment available as I do electronics as a job and hobby. However this test could be done with the a very 'low end' scope and current probe since the frequency of the waveform is so low.
For comparison I may look at the voltage waveform at the starter to see if that gives a usable result. If it does, the current probe would not be needed, but I've heard the voltage method is not as clean of a waveform..
Finally here is the current clamp on the positive battery line:
Equipment:
Oscilloscope: RIGOL DS1054Z. (overkill for this job but I already had it)
Current Probe: Hantek CC-650 (Note: There may be a cheaper option. The minimum specs would be something like AC/DC capable, 500A and 1 kHz frequency response)
UPDATE (8/3/19):
I added a voltage probe connected to the "+" battery line and re-ran the test. Basically the voltage waveform is not as useful due to 'noise' and lower peak to peak amplitude but you can still see the pattern. Also note the the voltage level is inverse from current. Each minimum occurs during maximum compression.
Using an acquire mode that reduces bandwidth and/or averages samples cleaned up the waveform. My scope calls this "High Res" mode: The waveform below is using the "normal" mode. Notice the high frequency noise:
tommys2patrick
374
Livermore, Colorado
Thanks for posting and the great details. I presume you are in fuel off mode while doing this test so the engine won't actually fire. If you did an actual compression test on at least two cylinders can you create a relative scale of compression values?
CMPPhil
379
Temple, NH
Hi Martin
Very interesting post, interested in the current probe you used, in the test. Can you give us a little more information on it?
Wonder why this approach would not work on any multiple cylinder engine. With a little more information I'd like to try it on the gas engines on my 3 trucks.
As you say it would make a good bench mark test, against future diagnostic efforts.
Cheers Phil
martinv
58
Glyndon MN
Yes, fuel off so it doesn't start. I got the idea from seeing it done on gas engines.
Look up youtube video: "Method for Relative Compression Testing to get PSI DATA!!".
scannerdanner also has some good videos on this procedure.
I updated the original post to include equipment makes/models.
CMPPhil
379
Temple, NH
Hi
Thanks for adding the details, with that extra info the game can begin. I've got a 4 channel Tektronix Scope, so the current clamp was the key. Think this will lead to some interesting playing with engine on test stand. First thought is to put current on one channel and voltage on another see how they compare. Oh yes this as the looks of a good winter project.
Cheers Phil
martinv
58
Glyndon MN
While I had all the equipment ready to go I decided to do this as well. First post updated to add the voltage and current results.
