relay ID
choll
Las Vegas,NV
What does the relay on the left do? My accessory fuse is loose and when I push it tight the left relay clicks. The one my finger is touching
cmroles
Phoenix, AZ
Its either the Voltmeter Relay or the Gen2 Relay. On my truck the relays had all been taken off the mounting plate and put back in the wrong locations so I'm not sure of the physical position.
If you pull one and the Gen2 light stops working then that's the Gen2 relay. The other one would then be the Voltmeter.
Warthog
231
OKC, OK
If those are under the dash in the center of the truck, then yes they are the Voltmeter and GEN2 relays. They should be mounted on a bracket along with the Starter Relay.
combatmech
Carrollton, Texas
Your Voltmeter might need a new 300ohm resistor. Radio shack has them. At least thats what fixed mine. As far as your heater fan....check fuses, and the connections.
Check this thread.....
Voltmeter is not working (at all - never moves)
