Remote car starter
Lazboytt
Michigan
Hello
I’m new here and just picked up an m998.
Anyone ever install a remote car starter on one? Trying to find one that is a 24v setup or a work around to make one work. I have been searching for days with no luck. Hope this is not a duplicate post.
Your help is appreciated
Coffey1
502
Gray Court SC
You might find one.
But if not you would need a 12 volts going to a 12 volts relay with the 24 volts coming off that relay.
orgnal
Denver, CO
Hello
I think summit racing has one ...
McReddy
Lazboytt
Michigan
Hello
I talked to summit racing last night with no luck. With regards to timers I believe most systems for diesel have a programmable option for timed delay.
i was thinking about the relay option but than you would also need a converter from 24 to 12 so the system would know it’s running.
I have found alarm systems that are 24v but no remote starters yet.
Dock Rocker
73
Jackson ms
I just don’t know that a 20 plus year old diesel needs a remote start.
I would want to make sure I had oil pressure and everything sounded like it is supposed to when I crank it.
Action
1,564
East Tennessee
When i had a 3speed trans, i left the shifter in gear when parked. A remote start would not work unless it was in neutral.
StackJ
-2
SoCal
Assuming the above (a delay, neutral, etc):
1. You could do a bluetooth solution going to a Raspberry Pi controller. There are numerous open-source projects for all sorts of actuators.
2. People get hung up around 24/12. technically, the lowest tech solution would be to fire a solenoid which would close the power circuit with a second one to close the ignition circuit a short while after. Heck, the circuit could even monitor the go-ahead signal for starting.
3. A higher tech solution would be to establish in protected parallel an entirely new power-start sequence.
Personally, I don't think it is worth it. Unique but I can think of 20 other Hmmwv things to spend my time and money on. This is too much of an edge case. Instead, buy a $36 block heater, walk out and start it and go on down the road.
