Corvette1974
- 1
- 18
- Upper Black Eddy, PA
Hello all.
I plan on doing an NV4500 swap into my M1028 this summer. I have locally sourced a pedal set, but I'm looking for some insight into this pedal assembly.
It is from a 1987 Chevy (IIRC) C10 with an SM465. It is vacuum brakes and hydraulic clutch. Would this be a suitable set? It might also have a tilt column so I'd take that too.
What should I take from this truck for the swap? It isn't a diesel, however.
Also what should I prepare for to remove the pedal assembly and hydraulics and steering column from this truck? It's in a junkyard so like a tool list would be helpful I don't want to be unprepared!
Thanks,
Will
Thanks,
Will
