Removing bell housing from block
Crowem87
Denver, co
Looks like I need to remove the clutch plates to access the interior bell housing bolts from the block. Motor is seized any ideas how to access these bolts? I can’t spin the flywheel to access the other bolts on the clutch plates.
NDT
6,280
Camp Wood/LC, TX
Unbolt rod caps and main caps, remove timing cover, balancer, etc., this will allow the crank to raise up and to turn.
