Removing blower housing
Crawdaddy
Louisiana
I am trying to replace my oil filter housing on my MEP-003, and to get it off, I have to disconnect the oil cooler lines inside the blower housing. I removed all the obvious bolts around the perimeter of the housing, and tried to pull it off. It seems like it's not wanting to come off around the air shutter assembly. So, what's the trick to getting this blower housing off the generator? I've looked in the -12 and -34 and neither seems to explain how to get it off.
Thankis for the help.
glcaines
2,805
Hiawassee, Georgia
I feel your pain. I dropped a wrench down inside my blower housing once. I took out all the obvious bolts and could never get the blower housing removed, although it was loose. Fortunatley, i was able to snag the wrench and get it out so I never completely removed the blower housing. I'm sure someone on here can help you.
steelandcanvas
87
Southwestern Idaho
Crawdaddy, I removed mine last year to media blast and paint. I recall it being a bear, just when I thought I had all the bolts out, something else was preventing removal. I just studied the diagrams of the cooling system, the -12 & -34 doesn't show all the fasteners holding that shroud to the engine block. I know there was a bolt down at the bottom I missed trying to remove the shroud, maybe you did the same? I wish I could be of more help to you.
derf
13
LA
On the MEP-016B there are little sound deadening panels of foam that are under the scroll cover. You have to remove most of them to find the attaching bolts underneath.
I haven't been into an 003, yet, but I think I might soon.
RichardR
Austin, TX
What's still holding the blower housing on is one of the three bolts (in triangular formation) that hold the round air screen on the front of the unit. Had the hardest time figuring that out myself. To look at it, you'd think those bolts only hold the air screen to the blower housing sheet metal, but one of them goes through the blower housing sheet metal and screws into a bracket on the engine block. I'll bet there have been lots of these ripped off by frustrated GIs. :oops:
jbk
livingston la.
besides the one on the grill up front theirs also a small 3/8 bolt up on the shroud on the batt. side that screws to the oil cooler bracket.
Crawdaddy
Louisiana
JBK was right on. That was the bolt I was mising. Because it's in the middle of the shroud, one thinks that it's holding something onto the shroud, and not the shroud onto the set.
I still can't get the set started, but that's for another thread. Thank you all for your help.
