Removing GL Bill of Lading Pouches
Dodge man
Fl
The best way that I've found is to heat the surface with a heat gun. Then soak in Goo-Gone or something similar and then cover it with Al foil to keep the GG from evaporating as fast as it does in the open. Let it soak or a few minutes and then wipe and/or scrape to get it off. I use a plastic or wood scraper to prevent scratching the surface. Then rub the goo off with paper towels. They load up quickly so you have to keep turning over to expose a fresh surface.
bchauvette
12
Easley SC USA, 29640
How about all that Paint marker they write all over with. They just about covered the whole left door on the MOG with numbers and codes as well as the front bumper .
jw4x4
Dayton, Ohio
If the paint is CARC, use brake cleaner to remove any paint and/or adhesive residue. Gently rub with a rag. When too much pressure is applied, the rough texture of the CARC can shred the rag and cause another mess. It will look good until it dries, then the rag residue remains. At that point, I just clean it again until it's all gone.
