Removing HMMWV run flat
jeepin
11
Vermont
Any tips on how to remove the "new" run flat from the HMMWV radial tire? Not the two piece magnesium one, the one piece hard rubber one.
Thanks.
86humv
496
Texas
8 bolt rims have the two piece Mag. runflat.
Only good for Bias tires.
Greg
Alredneck
Banned
1,494
15
TN
the runflaats work with both bias and radial. But they say dont put radials on bias rims. Citizensoldier squared me away with the load ratings are different is the reason. By the way if anybody is looking for the new rubber runflats then we have them as well as just the plastic beadlocks, most are new still in the package. PM me for details and prices. We also have both Bias and Radial HUMVEE tires as well!
Barrman
1,712
Giddings, Texas
Another way is to put an engine hoist legs over the tire, wrap a chain around the run flat and start pumping. I have done this with LAV tires and the HMMWV tires. Works just fine.
1,806
I like that idea Barrman. Hey Captain, the plastic ones, those the PVC pipe deals? Might need to buy some when I can.
jeepin
11
Vermont
Yeah after starting with the ratchet straps I ended up with a pickup on one end and a maple tree on the other....it popped out
Alredneck
Banned
1,494
15
TN
Kenny they are made out of some type of plastic but not pvc, these are military issue. I got new ones in the cardboard bags. Will get pics when I get back to the house for yall plus the nsn number.
Barrman
1,712
Giddings, Texas
The HMWWV with the two rubber run flats is just the same. Hook onto the big one after you push the small one out of the way and go for it. I did that a year or so ago on some.
dirtyfingernails
Gainesville, FL
If you want to reuse the runflat, how do you get it back in? My first one I could not get out and since it ticked me off I cut it. Another question. Do I HAVE to use the runflat device in my new tires?
