Ever since I bought my MEP-003, I've had an oil seepage from the area of the oil filter. The seepage is not bad and doesn't occur when the set is off. It will leak just enough oil while running over a 1 hour period to cover the tray below the filter and the frame below the oil filter in oil. However, it's slightly annoying to know it's leaking and to clean it up every couple hours. From observing the set, I am fairly certain the leak is not coming from the oil filter can itself, but from the gasket between the oil filter adapter housing and the engine block. The housing is item 31 in the picture and the gasket I believe is leaking is 32.
I've pulled the adapter housing on a MEP-003 before on a machine that ended up being junk and I never got started. It involved pulling several bolts, removing the oil cooler lines, and somehow finagling the adapter through the metal plate at the blower end of the engine. Trying to make sure the gasket stays in the right place and making sure it doesn't get torn while trying to wrestle the adapter in place seems very difficult to nearly impossible. Am I missing something to the process that makes it tolerable? I haven't tried re-torquing the bolts for the housing. Could that possibly take care of the seepage? I will be switching to the Speddmon oil filter adapter to make oil changes easier in the future.
![mep003 oil filter base.jpg mep003 oil filter base.jpg](https://www.steelsoldiers.com/data/attachments/342/342834-6734c54bcd8934abbb2631c27281f2c8.jpg)
