Hello everyone...well I replaced my fuel filter the other day since it had been about a year since it was last changed out...after doing so I let it idle for awhile...10-15 mins or so and it ran just fine like it always has. A short while later I drove it home which is about a 10 min trip and it ran great until I pulled in to park and noticed it running rough and smoking (white smoke) more than usual. I let it sit overnight and got it back up to my workplace still running in the rough not so good condition...thinking maybe something was up with the fuel filter I removed it and checked to see if anything looked amiss but it all looked OK. I reinstalled it and after bleeding the air out it ran fine again for a minute or two before it started running rough and smoking again.
I figured it might be a faulty fuel filter so I exchanged it for a new one (WIX) and it did the same thing again after I got the new one on...ran fine for a few mins but then started running rough and smoking...it runs fairly smooth if you give it some throttle but will still smoke. In this condition it also runs a lot quieter than a 6.2 usually sounds...sounds kind of sick...in a bad way. Could it be a coincidence that the fuel pump or injection pump may have been on the way out and it just so happened when I changed the fuel filter? Both of them are still original to the vehicle...if anyone has had this happen to them or knows what the problem could be I would greatly appreciate your assistance...thanks in advance...
