Replaced starter solenoid today
cranetruck
94
Meadows of Dan, Virginia
Every so often I get the chatter from the starter solenoid on the 8x8 and really hate it when showing the truck to someone for the first time...it just leaves a bad first impression.
Last year I bought a solenoid on ebay and upon closer inspection it turned out to be the exact right one for my 8x8, no numbers to go by, but dimensions and features match perfectly. :)
So, this afternoon I went ahead and replaced it and the key thingy here is that it was rather straightforward even with the starter still on the engine.
I'll complete the job tomorrow.
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
Good to know you don't have to pull the starter to replace the solenoid. You going to pull the solenoid apart and clean it up the contacts?
On a side note, I just replaced the soleniod on my 93 chevy truck starter. 18 bucks vs a new starter. Starter lasts forever, solenoids are good for couple of years.
cranetruck
94
Stretch44875 said:
Good to know you don't have to pull the starter to replace the solenoid. You going to pull the solenoid apart and clean it up the contacts?.........
Yes, the contacts will be replaced/cleaned up and the original solenoid kept as a spare.
After several starting attemps, the "chatter" is still there. It is obvious that the starter must be replaced also, but at least, if you are sure about the problem, the solenoid can be replaced without removing the starter....
