Replaced Steering Knuckle Boots
Tow4
640
Orlando, FL
I replaced the steering knuckle boots on the Deuce today and had a couple of observations.
First, when I got the truck I noticed the zippers always leaked a bit. Not a problem, it wasn't much so I didn't worry about it. Recently the passenger side zipper blew out so I figured now's the time to change them.
When I went to take off the driver side boot I noticed there was no RTV on the zipper! I unzipped it to remove it. Maybe that's why it leaked. Probably should have saved it since it was OK otherwise.
Second, I've read you need another pair of hands to hold the boot so you can get the clamp on. They aren't kidding. The inside clamp is easy because the boot stays on. It's the outside clamp that is the problem. After messing with it for a while I got some small clamps to use to hold the boot to the knuckle. They don't have to be tight. Just snug enough to hold the boot in the groove. Once you start tightening the clamp, you remove them and check periodically to make sure the clamp and boot are in the groove on the knuckle as you tighten the clamp.
1,172
Ray, I don't see the 4 nuts on the steering arm/kingpin cap.
Tow4
640
Orlando, FL
You remove two nuts and two lower bolts to remove the guard per the TM. You reinstall them and the guard after changing the boot. The two nuts in the back are still there. If you look hard, you can see one at the top of the drop light.
1,172
OK, Just making sure! :)
And I kinda forgot about the guard!:oops:
m816
Chatham, NJ
deuce boots
We did that job a couple weeks ago. The clamps are a good idea when you don't have soldier number two. Doesn't take long with two people. How long did it take by yourself?
1,172
Awe man, At the GA12 rally, GR and I did a pair on Carnacs truck. Does that make me GR's wife?
gringeltaube
Staff Member
2,420
Montevideo/Uruguay
:ditto:.... if you meant to say: ....put the clamp in the boot's groove...;-)
Yes, that's the "one-soldier" method: gradually work the boot lip into the (lubed) knuckle groove, with the clamp already on and "semi-tight".
G.
rednckii
Gulfport, ms
I still need to do this to mine just have to come up with the time to do it. Gettin taxes back this week so will be on road shortly. Going to do a complete teardown on front so i can look at bearings and brakes even though i have the zipper boot replacements.
Munk
Nelson, mn.
I have always done the boots with an extra guy (spare set of eyes on the other half of the boot). It only gets easier and easier. Next set will be slicone.
Tow4
640
Orlando, FL
M816, I had about 4 hours actually working on it. At least half of that was cleaning everything and scraping the grooves. Now that I know what to do I could probably do it in about 1 hour a side.
1,806
I've been pretty lucky. Always a one man show here. My experience is that if the boot and groove are absolutely clean, they are more apt tp stay in place. I can do a solid boot in 75 minutes in my driveway.
Motorcar
San Antonio, TX
It's a bunch easier if you have it on a jack stand and pull the wheel off. Then you just slide up to it sitting on a creeper and give the drum/hub a hug as you work the boot on. I opted for the no-wife help and found my knees could hold the bottom sides of the boot while I worked the top in and tightened the clamp. Where there is a will there is a way!
Where does Gimpy get those avatars?rofl
