Replacement nuts for head studs
JasonS
200
Eastern SD
I am doing head gaskets on an LDT and thinking about replacing some of the rustier nuts. Anybody know what class of threads the stock nut has? 2B, 3A or ?
1,191
Try looking at the part numbers from the TM, then google it. Look at the parttarget link for all the details needed to replace.
JasonS
200
Eastern SD
Fastenal has a line of grade 9 nuts with Ecoguard coating that withstands 1000 hours of salt spray. However, the thread class is 2B.
1,191
Here is a direct link, http://www.parttarget.com/.
You can either use that and search the part number you need or, just Google search the part number you need and usually their is a search result that is from "parttarget".
