Replacement Panels??
sandcobra164
291
Leesburg, GA
Does anyone have or know where to buy replacement sheet metal for a Deuce? The panel just forward of the windshield but just behind the hood is showing some rust damage and I'll probably have some new holes there soon. I'd like to replace the whole panel and weld in a new one if there's anything like that available. If not, it'll have to be fabbed up locally I suppose.
Thanks,
KsM715
142
St George Ks
Do you need just a small patch panel. Or are you talking about replacing the whole cowl? If you want to replace the whole piece its been said its easier and less time consuming to replace the whole cab.
But there are a few guys here building quad cab trucks. They might have the cowl piece you need. Try ccequipment, He is building one right now and might have left over pieces.
sandcobra164
291
Leesburg, GA
I'd like to cut our a good section and replace most of the cowl. Good thinking on CCE as far as tracking down a replacement. He's going crazy with crew cabs now and maybe I can get him to carefully cut one just past where it curves down and I can weld it in.
