Replacement wheels/tires for M149 water buffalo trailer
juanprado
2,870
Metairie/La (N'awlins)
The standard tire is a 9.0 x 20 bias/nylon ply ndc. Same tire as a deuce. I have seen some use radial 11.0 x 20 on the sister trailer m105 series. Not sure if you want to go taller with the weight if you are going to fill all 400 gallons? Trailer is prone to rollover with water sloshing around on uneven terrain and driven poorly.
