Replacing Deuce air tanks/Hints and Suggestions please.
Scrounge41
St. Augustine, Fl
I took my '73 M109A3 for a spin on Memorial Day and when I returned to my house, cooled it off and shut it down I heard an air leak. Crawled underneath and realized I had a pinhole in one of my tanks. Rather than gamble on take outs, I got 2 NOS tanks. I searched the forums and didn't find any posts on switching out the tanks. Of course I have downloaded the manuals, but I thought I'd pose the question of whether anyone had tips or tricks on the swap out or if there is anything else that should or would be easier at this time. Thanks all.
SCSG-G4
PSVB 3003
3,322
Lexington, South Carolina
If it has a pinhole that has come all the way through, there are probably thousands of others just waiting their turn. Replacing the tanks will entail far less work.
Scar59
41
Mt. Eden, KY
Pretty easy task. Spray the tank clamp hardware with PBS Blaster, disconnect all the plumbing and relax an air line or two and they come right out. Tough part is sitting under the truck. You can weld patch the leaker, however you most likely have another leak down the road. Install an auto drain valve in the primary tank.
Scrounge41
St. Augustine, Fl
As I said in the first post, I already have the new old stock tanks as I did not want to risk the same problem with installing used tanks or by repairing the existing tanks. It looked to be pretty straight forward. I had already installed a retrofit government issued pull cable drain valve. Thanks for your input.
