- 2,114
- 565
- 113
- Davis County, UT
Hey all,
For the life of me I cannot seem to dig up the dimensions on what is the proper length x width x thickness for the deuce's bow sides (that hold up bows and cargo cover).
Many of my bow sides are the worse for wear and some could be reused with sanding + painting, but I think it'd be best just to replace them all. In other words I think it'd be less work to just cut new ones, drill new holes and paint them, then try to sand down the old weather worn ones with multiple holes.
I have a full set of bow sides that came with the truck but I don't trust them to be right since they seem to be a hod-podge set. Current dimensions are about 61 7/8" long, 2 3/8" wide, and 7/8" thick.
Is this correct, if not what dimensions should I cut the new ones to be?
Oddities:
Two of the bow sides are actually much shorter than the others, but they're not broken. Two of the troop seat's bow side slots (on the passenger side) have something in them that makes one of the short bow sides the right height, the other is still a couple inches too tall. Peering down the inside of the troop seats with a flash light, I can see a section of wood inside the hole that has clearly been cut by a saw. I haven't yet pulled off the troop seats to try and discover the purpose for the section of wood down there. I can only guess that perhaps the metal "leg" of the troop seat was damaged in someway and that the wood was placed inside to sturdy/support the seats when the cargo cover was not mounted. Has anyone else seen something like that before? I'm not sure if pictures will be able to show it...
That all said, fortunately, I believe my bows are in well enough condition to be reused, perhaps not even needing any paint!
Oddities:
