Reset Decal
csheath
197
FL
I see some units with a decal reading RESET. Does this indicate it HAS been reset or SHOULD be reset?
glcaines
2,479
Hiawassee, Georgia
I'm assuming here that you are talking about a genset? Normally, if a Hobbs meter is labeled as 'reset' it means that it has been reset. This is a common practice in the military when equipment is rebuilt. Usually, reset labels are not applied when the meters are replaced or run back. Never believe what a Hobbs meter is reading unless it is obvious that the equipment is new and unused.
csheath
197
FL
I am referring to generators. The decal I am talking about is a large white decal with black letters that read "RESET". It doesn't seem to have any relation or reference to the hour meter as I have seen this decal on the outside of the panel cover on a lot of units with different hour readings.
Guyfang
23,030
Burgkunstadt, Germany
Often, you will find a decal or data plate on the right side of the gen set, or engine, when the generator has been reset. But not always. Its to the left of the coolant overflow bottle, most of the time. Gives info on the who, what and where of reset to that gen set.
The decal you are speaking about is normally applied when the set is finished reset, before shipping, to differentiate between a set ready to ship, and not ready to ship.
TrailLifeBill
Brunswick, GA
I'm assuming you are referring to the unit you just bought from GL. Mine had the same sticker on the outside of the unit - but no other labels/tags on the engine like some I've seen on here. My Hobbs shows roughly 6600 hours, but the exhaust manifold paint is still fresh. All hoses/belts look new. Gen housing paint looks rough, so mine appears that a new/remanufactured engine has been dropped in. Mine was a USMC generator, and runs like a top! Good luck with yours.
