Resistor Bypass
Warthog
229
OKC, OK
You can use the existing wire on the resistor pack and connect it to the 12v terminal block.
Or you install a new wire. The wiring diagrams show that the wire is 8ga with a 12ga fusible link for protection. If usu\ing this route you will need to run it to the front battery positive terminal.
