Reverse lights
Dhjmd
Morton IL
Anybody have a schematic for adding a reverse light to a M923? I want the light to come on in Reverse only (vs having it on a switch in the cab). Can we use the pressure port on the side of the tranny and wire power to the light that is only switched on when the case pressure inside the tranny (in Reverse) trips the pressure switch? Thx for any help you can provide!
Jbulach
2,138
Sunman Indiana
I still haven't figured out how to make a link using Tapatalk.
Search for tread "M939 5-Ton reverse light switch" by Superman
juanprado
2,814
Metairie/La (N'awlins)
Yes, It is easy.
Check my truck build under "major Zippidy" as I documented and also added a back up alarm at the same time. Pretty straight forward.
