Revived old member
4jfk
Tennessee
Hello friends,
I'm an old member who just took a long sabbatical. Lol. I'm finally hooking up my dump on my deuce. I'm needing a few parts. Linkage and brackets, and an auxiliary unit for my existing PTO. Can anyone point me in the right direction? Thanks
4jfk
Tennessee
I'm converting it sir. I have the PTO, winch handle, but no bracket to mount it to, and I have the original valve, pump on the self-contained bed tank. Thanks
m16ty
218
Dickson,TN
The PTO rear output is hard to find. It may be easier to get a transfer case PTO, or if your aren’t planning on having a PTO winch, just drive the pump off the front output. I’ve done it both ways, if you need more info.
Edit- I see in your other post where you have a factory pump and valve. You’ll probably have to use a rear output PTO unless you modify your existing pump. I don’t know what to tell you, but good luck finding a rear output.
