Riddle me this (wiring harness)
Pinkie
hague, va
I need to replace my front wiring harness. I bought on wiring harness at aberdeen but after getting it home I doscovered it was not the right one. No problem. I looked up the right one and ordered it. I get the new on in tonight and discover it is not the right on. The one I bought at aberdeen have and big 60 amp alternator plug but it has a few connections that are ring terminals. The second one I bought has all the correct water proof ones, pachard I think but has a 3 prong plug for the charging system. I do not know the difference between the 2 prong and the 3 prong. So now I am covered in cosmoline (that will not come off) and I need another cool beverage and I am confused . I am looking for some advice on what wiring harness I need.
Pic 1 - what it took to determine the mix up
PIC 2 - helper
PIC 3 - wiring harness that has the correct water proof terminals but has the 3 prong charging circuit
PIC 4- has the right 2 prong alternator plug but has ring terminals while my truck has water proof connectors.
m-35tom
226
eldersburg maryland
either harness will work but there are many variables. you will need the harnes to adapt it to your alt assuming you have one. you may need a seperate harness for turn signals to go from 6 terminals on the harness to the flasher and turn switch. the big thing to look for is does the new harnesses have connector for the push to start switch? and does it have the air shift transfer connector? saturn has the mostly correct harness for about $45 but you have to add the turn harness and the alt harness ( you can easily modify for the alt instead of adding a harness)
Pinkie
hague, va
The harness that has the "big" 2 prong alternator plug has ring terminals where water proof fittings should be for the solid state turn signal box on the fender. The harness that has the 3 prong charging system plug has the light for the front axle switch. Both have the correct push button plug for the starter. My truck has the "big" 2 prong plug right behind the motor. Which is easier to modify? I really do not want to modify either, I would rather have the correct harness thats is just like on the truck now. Thanks m-35tom for your information.
Pinkie
hague, va
Harness I bought at Aberdeen is NSN 2590-00-076-6001, has the 2 prong plug for the charging system
Harness I ordered is NSN 2590-01-016-3187, Part # 11677081 that has the 3 prong plug for the charging system.
Pinkie
hague, va
I enjoy my Miller Highlife because no one else will drink it.
The correct harness is 3187. AmGeneral had to beat it into my skull that I had to remove the Alternator Adapter Kit (2 pin big plug) because this harness was all inclusive. I again give a be thanks the AMG to make my 2 brain cells rub together to create enough heat to make sense of this harness. By the way, this harness bag had June 1986 stamped on the bag when I got it this afternoon. I hope this has helped other people as is has helped me figure out what I had to do.
Pinkie
hague, va
I got the dash done today. There are 2 adaptor "Y" connectors that did not have the be used when putting everything back together as the new wiring harness has the correct number of plugs needed. It seem that if there was a update wiring kit available, it was installed on my truck by the military. If I count correctly, the new harness will replace at least 3 different ones that are currently on my truck. I will include pics and have another update tomorrow as it is raining I am do not have a shop yet.
1,193
Unfortunately BC is no longer with us to need that info.
Maybe it will help the next guy...
renodogs
Reno, Nevada
Which exactly the point of the post.
Happy to see someone else that sees the value of sharing information. Here's something to consider for those less inclined to mind their manners when information is shared, say 'thanks' and be on your way.
Some of the folks who actually find something out are more willing to share it if they aren't mocked, chastised, ridiculed or belittled by the self-appointed demi-god sourpusses on this website. :roll:
rustystud
3,392
Woodinville, Washington
Sadly there are a lot of threads that have ended with no answer, just like this one. I believe it's a good thing if someone does come up with the correct answer and shares it with the rest of the community.
renodogs
Reno, Nevada
Yes, I agree. As to why the posts go unanswered, just check some moderators behavior and you'll see why. As for me, I'm not one to be intimidated by the 'rotten toothed alligators' that cruise this swamp, nor should anyone else.
1,193
Please PM me or any of the other mods if you think there is a problem with any of the staff.
You can also report any post, anytime. This will let us see and deal with any issues, fast and easily.
From your own advice, in post # 14, you might have just said "thanks" and moved on.
