Rim specs
msgjd
4,075
upstate ny
it appears you're transitioning away from the OEM rims and 900x16 tires .. Don't forget to check the clearance the inner dish of the replacement rims have on tie rod ends etcetera, especially at the extremes of left-turn and right-turn. How much ground clearance are you gonna lose?
rollingscrapmetal
Phoenix, Az.
Theyre also 16 inch and about the same width just flatter across the front so they should clear everything better as far as ground clearance it has 9-16 on it now which looks to be somewhere between 35 and 37 so i was looking for bigger tires idk what size though
