Rim/Tire identification
tfhummer1
Bayard, Nebraska
Hello guys need some of your knowledge. I have been searching through posts for two days and cannot seem to find a clear and easy way to tell what these rims are from and if they will fit my M35A2C with just an adaptor or not. The tires are 1200x20 Goodyear MSA and the rims say Hutchinson and are aluminum. I thought these might be MRAP rims but I don't know, since all the MRAP I have heard about came with 395's. Hopefully these will work on my truck and I hope I didn't overpay for them. I gave $1300 for 8 tires and rims, both are new, and also have the run flat in them. 20160924_115052.jpg
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Yes, they look like the Al mrap rims. Whats the bolt pattern? That will tell a lot. Any better pics of the tire?
Yes, SMOKIN deal on them!
NDT
6,487
Camp Wood/LC, TX
I think those fit the rear axle of International Maxxpro MRAPs with dual rear wheels.
NDT
6,487
Camp Wood/LC, TX
Can you snap a picture of the other side of the wheel inside the dish? Also what is the bolt circle diameter and spacing of the flange bolts? Also what is the ID of the wheel inside the rim? With these measurements, you will be able to determine if the available adapters will fit inside the rim and match the bolt circle of the flange bolts.
NDT
6,487
Camp Wood/LC, TX
Looks like a Peashooter adapter might work. I would get him to send you a copy of the print of the adapter so you can double check before you drop coin.
73m819
325
gainesville, ga.
I would like to find 8 + of these tires for the back of the 819, no rims just tires.
98G
Former SSG
4,423
I don't think these will go on your deuce. The backspacing looks wrong, and this doesn't look like the Aluminum MRAP rim bolt pattern to me.
Peashooter should be able to give you a definitive answer...
peashooter
205
Hanover, minnesota
Yeah 98G is right, those are aluminum MRAP wheels but they are the goofy ones that have the same bolt pattern as the 5-tons. So they Will NOT fit a deuce with an adapter. I dont think the aluminum ones even fit the 5 tons since they are so thick i remember reading how they rub on thr brakes.
They are probably worth a fair amount in aluminum scrap.
