Rims from SE Virginia to Gilbert?
steelsoldiers
3,975
Charleston, WV
Anyone headed up to Gilbert that could haul 6 or 7 super-single 939 rims to the show? I have a fella that is interested in them, but I'm not going to the show. Thanks!
steelsoldiers
3,975
Charleston, WV
Thanks Mike. I may take you up on that unless I can find someone heading up from NC. It is a pretty good haul to your place for me and I'm not sure if I'll have time to do it between now and then.
maddawg308
762
Appomattox, VA
I'm going to VA beach in a couple weeks, can pick up on the way back, if that works out. How big are these rims? Just need to know if all I have to do is clean out the Durango, or rent/borrow a trailer.
BKubu
1,154
Gaithersburg, MD
Mike, these are rims for the 1400X20 that go on an M939 series truck. They are fairly big. I'd say that you will need a trailer. Plus, unless Chris has removed the tires, most still have rubber on them. They probably weigh in the range of 300 lbs. per tire/rim.
steelsoldiers
3,975
Charleston, WV
Yep, forgot to mention that 4 of the 7 have tires on them still. Thanks Bruce. They are heavy buggers. I have another local guy interested. Hopefully he'll buy them and I won't have to worry about it :)
steelsoldiers
3,975
Charleston, WV
Bump. The local guy didn't pan out and the guy that's going to Gilbert is still interested. Anyone else headed North? Thanks!!
