Roof lights/top cab lights
anjay22
Seguin, Texas
I tried to do some research to see if some folks put up a light rack on their cab and found nothing. does anyone have any ideas/advice on what i should do to make this happen?:grin:
Josh
12
Portland, Oregon
I built a light bar that utilizes the convoy light/gunring leg mounts on the back of the cab. Plan on running 9 6" 100w lights. Bout a bunch of the HF 6in housings and replaced the bulbs. Ill try and track down a picture of it for ya. Its currently off of my truck.
980
24
Dover, New Hampshire
I'm building one that will mount to the outside of the windshield frame like the ones on a wrangler. This way I can leave clearance to remove the top, I had also considered giving it a 90 degree folding capability so it will still face forward if the windshield is folded flat against the hood.
saddamsnightmare
80
Abilene, Texas
:whistle:June 21st, 2012.
Perversely interesting! Why not just mount a 24VDC landing craft light like the Pittsburgh Railways Interurban PCC's used on the roof? 1 light and you will set trees in fire a half mile away!
M1031CMT
11
Ontario
Build/Install a roof basket. That will give you a perfect place to mount lights like I did on my truck.
I can give you a link to a pdf which contains instructions from the military to build a roof basket for the M35 if you want.
Woodstock, GA
I mounted mine on the forward most canopy bow and I shortened the legs by about a foot so that the lights sat closer to the roof line. In the future I will probably weld this assembly to the outside front of the bed so I can still use the cover if I want. However, I kinda like how it is now because I can quickly remove it if I need to.
I got the lights on sale at harbor freight for like 8$ each. I then installed 24v 100w bulbs and spray painted them since the chrome just didn't look right. They are powered from a McMaster Carr distribution block, four 24v relays, four in line fuses, and are switched from an under dash switch buss that I made.
Titanium Soldier
Mojave California
Would work great but they may burn up, i did a little looking into it because i have a few sitting around (dont ask me why cuz i dont know) but most will over-heat quickly, gotta remember they are on at speed and the taxi lights burn out all the time because of low airflow
M1031CMT
11
Ontario
DeucesWild11
12
Putnam County, NY
You may find that 24v lights can be pricy, if you find some cheap 12v ones you can always change the bulb itself like Rambling Wreck did. I did the same with my off road lights on the front..
lost in the bush
Indianapolis, Indiana
LED Lights 9v to 40v.. Can go low dollar up to Ridge Industry 50" strips.. Suggest before you permanently mount any lights test them at night to ensure you do not have a major glare on you windshield.. I did not take my own advise with a set of LED on my F150 roof rack ..
748
Woodstock, GA
Yeah, I think I paid something like $4/each for the 24v bulbs. That brought my total cost to only about $12/light.
