chriskonen
- 0
- 0
- riverside/new jersey
Hello all,
I rarely post here on SS but I'm looking for some input/advice from some of the veteran M880 owners out there. I just started my M880 restoration today by replacing the power steering pump and the master cylinder. Upon bleeding the master cylinder (no air bubbles in the reservoir) I noticed the brake pedal being "loose" for more then 50% of the stroke and only getting some tension in the last 1/3 of pressing the brake to the floor.
Upon inspection sure enough there was fresh new brake fluid pouring out just behind the cab on the driver's side inside the frame rail. I ran my hand along there since view is obscured by the gas tank and the metal fuel line was clearly loose and didn't feel as though it was attached to anything. My guess is the fuel line is broken off or rusted through at minimum.
How difficult is it going to be to run all new brake lines for this truck? Any suggestions or tips? I got the truck cheap ($1000) and it had already been converted to power steering and it does start and runs strong. However the thing is almost completely rusted out. I'm trying to restore the truck and am doing it on a beer budget (domestic not imported). I really don't want to give up on this vehicle. I want to get it on the road and save it from the grave. I'm frustrated but I just don't know how to give up on this project.
Thanks,
Chris
Thanks,
Chris
