yokurto
- 5
- 3
- oak hills, Ca.
I became the proud owner of an Empire 50 kw with a White 2300T diesel with a Roosa Master DB2 IP. The flex ring failed and the check valve plugged with debris. I decided i wanted to attempt teh flex ring repair myself. I am having trouble getting the vent wire screw and the cam advance screw out. they are very tight and i am afraid i will strip the heads ( I am using alan wrenches as i don't have the recommended tool). does anyone have a suggestion i am afraid to ad heat but assume there is no other way. any help is greatly appreciated ....
