RTTY S-250 Heater hook up
firefox
General
51
Berkeley CA
Has anyone ever hooked up the heater in the s-250 to the 5gal can mounted on the bulkhead just to the left of the door?
The heater has its own fuel pump and there is a fitting on the bulkhead just below the 5gal can so that a hose goes from there to the 5 gal can.
My problem is that I cannot find the reference to the adapter that is used
for the 5 gal can. I have a gravity feed adapter but that is used with the can upside down.
The pictures in the s-250 TM clearly show an adapter with the can right side up. I am pretty sure that it is just a
different style of adapter which has a suction tube on it instead of an air bleed tube.
Has anyone come across one of these
and possibly knows a TM that has a detailed picture of one of these?
Thanks for any info,
Bruce
firefox
General
51
Berkeley CA
Thanks, that's the one I have. This one requires the 5gal gas can to be inverted.
The one I am looking for has a pickup tube going down in to the can just like the pickup on a vehicle tank, but without the pump. Pump is in the heater.
Thanks,
Bruce
m38inmaine
47
Maine USA
The adapter is the same for the MEP-002A/3A gensets. I have one with my S-250 GRC-142 shelter/heater. It is a common item should not be too hard to find.
firefox
General
51
Berkeley CA
That looks good! I have a NOS heater so I am set on getting the adapter.
There is even a thermostat in the s-250 that works with the heater.
Thanks for the pic!
Bruce
left_flank
carnation wa
or you can do this. i welded a half copling on the bottom to use this as a fuel tank on my 715 while getting it running
