rizzo
- 8
- 38
- Port Huron, MI
anyone know what these runflats will fit?
http://cgi.govliquidation.com/auction/view?id=805407&convertTo=USD
M1075, you are right the bolt pattern is the same. There are severa companies out there that will recenter the wheel pretty inexpensively now too.M1075 said:The bolt pattern should be the same, but the offset/backspacing is different. I plan to either change from SRW to DRW hubs in the front, add spacers, or recenter the wheels.
