roscoe
- 0
- 0
- Spencerville, Indiana
Well my poor multifuel engine is toast - i'm pretty sure. Just took a little time today to put on the new hydraulic head that I purchased a few weeks ago. Finally got all the lines hooked up and went to test it. Started fine after several seconds and I get out to check for leaks. No problems so far, so I shut the truck down with the throttle kill knob. I decide to back it out of the barn to let it run longer and check things further. I start it back up. Starts fine and I hop out to open the barn door more and move some things. Engine speed starts to ramp up dramatically. Sounds a lot like a jet preparing for takeoff and black smoke is pouring out of the stack and quickly filling the entire barn despite two large doors being open. I quickly pulled the engine throttle kill and nothing happen. It didn't slow at all all and continued to rev higher and higher. I had read something about runaway engines when I was researching my hydraulic head issues, so I had removed the mushroom previously and placed a 6x6 block of wood nearby, just in case. I ran around the truck and placed the block over the intake and pushed hard. The engine would not stop. I ran around, jumped in the cab and tried to put the truck in gear and kill the engine - would not go in gear and black smoke was engulfing every inch of air. I run to the other side of the barn, open the door, pull out my skidsteer, and with a close by chain and a fair amount of foul language, I get the truck mostly out of the barn only to realize I had left the door open on the truck. So at this point thick black smoke is pouring out of the barn and I'm just thinking this thing is going to explode at any minute. Once the truck is outside and still billowing smoke, I drive the skid steer around to the side of the truck and attempt to apply more pressure to the wood block that is still being suctioned to the air intake. This helps a little, but not enough to stop the engine. The engine finally stops itself leaving a good bit of oil on the ground and there is only sizzling noises. As I'm looking over my truck in disbelief and disappointment, I hear sirens in the distance. It momentarily crosses my mind that someone has called the fire department because of all the black smoke. And sure enough, a couple of minutes later there are multiple fire trucks and an ambulance headed down my drive. Well, at least my neighbors are attentive. I found out a little while latter that they had tried calling me first but didn't even know if anyone was home and thought the barn was on fire. Not sure what I'm going to do now with the truck. It had always run so well. Anyone care to speculate on the cause of this particular event?
