goldneagle
- 1,016
- 113
- Slidell, LA
After installing my rebuilt starter and charging the batteries on my M936 I got the truck started with no issues. I tried it several times without any issues.
Today i went to start up the wrecker to see if the batteries were still holding the charge. When I tried to crank the truck I could tell the batteries were very low. So I turned off the start switch and then the Battery Switch. I noticed the starter was still trying to turn. I tried giggling both switch on and off with no effect. Had to run to the other side of the truck and got the the batteries. Ended up forcing the ground battery clamp off the terminal. Got burns on both hands for my trouble!
Now the question is what went wrong? How do I proceed from here? Obviously I need to get batteries. Do I just hook them up and see if the starter is quiet with the switches off? Please advise....
