RickTheEngineer
- 5
- 16
- Mount Laurel NJ
Hey all, I thought I'd take a chance to try to explain a running light issue I've been having for a while, and after some time of working on it (a long time) I think in just about ready to try percussive maintenance haha. Okay, I'm going to try to explain this as best I can so bear with me.
First of all, since I bought my M1009, the left turn signal indicator on the dash was always solid when turning on the headlights on the running lights. And the left running light wouldn't not be on. Both bulbs are new and the sockets "seem" to be in good shape. But here is my discovery. In the pictures it can be seen that in one pair of pictures, the drivers side bulb is out, and the dash indictor is on for that side. But then, AFTER I TWIST THE BULB and twist in back in, it was fixed! However, then I turn in the left turn signal, or hazards, it goes back to not working again (running light). Also, when I was messing with it, during the process, I somehow managed to get neither to work, sometimes the problems migrated over to the other socket and whatnot. Now, more bizarrely, I actually got them both to work once, but then I turned on the dash lights, I blew fuses left and right (the same 20A fuse). The ground wgere the parking brake lever, the one by the coolant filler, and the one on the frame on the passenger side all were cleaned and are in great shape. I tested with a volt meter and I am getting voltage (from what I understand) in the right places. Just before the socket, I am getting a steady 12V on the running lights, and I am getting a flashing 12V when the dashers are on. I am beyond confused at this point so if anyone can please help that would be amazing. Also, my POSSIBLE SOLUTION is to get new sockets for left and right sides. (Already ordered, coming in this week). I am thinking that there might be some kind of malfunction in one of the sockets (probably the driver side) since sometimes the problem changes when you Jimmy the bulb. any input would be HIGHLY valued! Thank you, and sorry for the long post...
