USMCWARWAGON
- 0
- 0
- Lincolnton, NC
I just purchased my first Deuce. The guy I bought it from said that a friend of his tried to "turn up the fuel" on it and couldnt get it to run after that. So it has sat for probably a year until I got it. Got it home and there was no fuel at the injectors. I bled the filters pump lines, all the way up to the injector lines. I then pulled the injector head off and found that the retainer clip and what appears to be some sort of jet had come off the spring on the bottom of the injector head. I put the "jet" and clip back on, reinstalled the injector head, bled the lines and presto, I had fuel at the injectors. Tried to start it up, and it fired up wide open. Did that 3 times. Any suggestions? Also, I think the retainer clip and "jet" came off again, tried to start it again and now back to no fuel at injectors.
