I bought more steel for the frame and the hardware to mount the axle and a hitch. Mostly built the frame now to get it on wheels and attaching to the PU or deuce.
Yesterday the new axle perch's, 9/16" U-bolts, spring mounts, shackles, adjustable hitch mount and hitch, came. I had welded the frame up to fit the calculated spring width and the 788 box and an electrical enclosure to use as storage on the front.
Between the rains, I put the axle under the trailer frame and have it spotted and clamped in place. It needs 2 more cross-members, paint and then will have the box set in the frame.
There will be a 36" back porch built that counters some of the heavy tongue and also structure for expansion and sleeping on top of the box, like a canvas tent that covers everything when folded up. Left folded down, sleeping is in the box.
Will post pics when frame is together, ready to mount box.
I cut a 7,000# axle to width and when re-welding, put 1/2" of camber up on the axle (in the middle between old spring perches). The tires I'm using are very wide tread which seems to exaggerate the camber and will surely wear on the outside. Most camber on trailer axles is meant to make the tire track flat under a full load. My axle will never see close to it's capacity to cause it to flex flat. Should I reduce the camber and make the tire track closer to flat? I did put a very low toe-in on it too, which I would not change, just camber. Spring perches are not fixed in place yet, so now is the time to change.
