S cam air brakes on 809 series
simp5782
Feo, Fuerte y Formal
9,369
Mason, TN
tobyS
833
IN
Thanks Wes, I didn't get correct terms in search.
There is a huge amount of info in that post.
If an 817 were made to 4x4 and 16.00 on it, going to air and s on the rear would seem to be good mod for safety. Are air lock differential available for 5 ton?
simp5782
9,369
Mason, TN
Yes @74M35A2 has em
If you are going 4x4 just use an fds1800 in the front and a HD meritot rear that will have Detroit lockers and s cam brakes already
tobyS
833
IN
Thanks Wes. Do you have either? Who does that has realistic prices? Can you expand both numbers, model, etc.. for me to locate.
simp5782
9,369
Mason, TN
I've got an FDS-1807, 18000lb capacity. 6.17 gears. Budd. Hub to hub. 72c drive yokes Has wedge brakes cause that's common on steer heavies. $1500. With springs/hangars and steering cylinder $2000
I've got a a meritor SUHD meritor unit. 6.17 with. Detroit . S cam. Hub to hub budd. 1710 series yoke. $2000
You can find the heavy mrap springs at auction
Both of those prices include shipping
74M35A2
330
Livonia, MI
$2500 if you want a selectable air locking 5t rear axle. Has 5.8x ratio and hydro brakes but M939 air backing plates bolt right up to them as well.
I have all 3 positions, and 2 Detroit Locker nuggets for 5t as well.
tobyS
833
IN
How about a selectable diff air locks with wedge air and 6.17 gears??? The ratio of 809'appears to be 6.44 and I see gear sets for the 6.44 ratio are available at reasonable cost....wonder about a 6.17 set of gears to match the Meritor?
simp5782
9,369
Mason, TN
Doubtful on gears
TracTech Inc makes em.
I' know you can since the front tandem on the 916s is an air locker.
