S250G Data plates and Q's
randyscycle
Rhoadesville VA (where!)
I have started working on my S250G and I'm getting it painted and ready to install into my M715.
I have the main plate on it that shows the dimensions and its in great shape, but all the others have been removed. There appears to have been 4 and possibly even 5 other plates. The rivets were drilled for the 4, and there were another set of holes that may or may not have had a plate on them.
Was there a variety of plates depending on what equipment was installed in the shelter?
Most of the usual MV suppliers only list the main data plate on their websites, that is the same one I have now. Does anyone know of a source for the plates other than the standard one? Does anyone have a good clear pic of their S250 plates?
Thanks in advance for any input!
SCSG-G4
PSVB 3003
3,292
Lexington, South Carolina
Yes, the plates depend on exactly what was in the shelter. The S-250 I got had been a psych ops model that came back from Iraq. Mine had seven plates at one time. See attached.
randyscycle
Thanks for the pic!
Seems that there are a lot of varieties of plates from the few pics I have been able to scare up on the net.
Mine appears to have had 4 or 5 only. I don't know the exact use it had, so I can't be sure of which plates were used, but I would like to find at least something close to what it had to put it back to looking like a correct S250.
ONTOS66
Franklin, NJ
The data plates varied based on the equipment installed in the shelter. Mine was a RATT Rig (radio tele-type with a GRC-106 - all the radios had been removed unfortunately).
Attached is an over view shot of the data plates on the rear door, and a couple of closeups. Another clue as to what was in yours is the additional data plates on the inside, as well as the interior configuration.
The last photo is from another shelter, the one on mine is to faded to read.
Hope this helps.
randyscycle
All very helpful! Thank you!
I haven't paid close attention to the interior stuff yet. Mostly just a lot of schematics, but I will see if I can discern what may have been inside in the past.
