jasonjc
- 283
- 83
- Gravette Ar.
When I picked up my XM818, it would not start. No big deal no fuel, I assumed bad shut off so used the bypass. That worked just fine, untill I went to move it. That was a no go, tranfer case would not go into grear.
After working on the tranfer case I found the bolt that holds the shift fork to the shaft was lose and no safty wire. It should have beed tq to 120 ftlbs and safety.
Got that fixed.
Next was to check on the fuel shut off valve. After some troble shooting I found that the TM is all wrong. It truns out that the wires on the start switch were in the wrong places. It would only open when cranking.
Two small thing that keep a good truck down
Could some one do this intentionally or just two random events?????
Got that fixed.
