Safety modifications?
Lorax
Hampton Virginia
I just finished reading Wreckerman's post about his runaway, and have thought about brakes, and ways to modify these trucks for quicker access to shutting down an engine if the engine runs away, and if the brakes lines/wheel cylinders fail.
Here's what I was thinking.
1. Install a butterfly valve directly under the air filter mushroom. Something goes wrong, jump out and close the valve.
2. Install some isolation valves on the brake lines at each axle. If a wheel cylinder pops, close that axle off. If you're close to home or a shop, it might allow you to go slowly there for repairs while still having some brakes, assuming you still have enough fluid.
I'm just starting to convert my M818 into an M813 and might do these things at the same time.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Why not just get a CO2 bottle from a welding supply store and hook it up to a dump valve? Electric solenoid would work too.
Lorax
Hampton Virginia
A CO2 bottle should also work. Just mount it somewhere. Think a over-revving engine would suck in enough O2 to still run, even if a CO2 bottle was used?
gt1009
st.charles,IL
I think there was an episode of smash lab on the discovery channel where they tried to stop a car by spraying a fire extinguisher at it from a car in front of it. The car did stop, so I'm guessing co2 directly into the intake will shut the engine down.
ems4ty
restricted/ca
You are correct in the response of Smash Lab (or Mythbusters, Though I think it was Smash Lab Too) that used the CO2 fire extinguisher to kill a car engine while driving. They had to use a ton more because they were moving and in a lead car trying to kill a chase car... However, if you have, say a 10# bottle of CO2 and plumbed it directly into the intake, then yes, the engine would die hands down, no problem.
-Tyler
Pappa-G
Central, MI
I've always been more worried about roll overs! I've been thinking of somehow mounting a roll bar behind the cab thats tied to the frame. Just something other than my head to use as a pivot point when inverted.
gimpyrobb
27,786
755
Cincy Ohio
PappaG, I have been thinking of making a headache rack that is tied into the frame to replace the sock headboard. Kinda combine the two to serve both functions.
